Message |
The TT motor i'm getting is already fully dissembled. The guy pulled it apart to see what went wrong (spun rod bearing). The guy also said that he already took the crank to an engine builder and was told its borderline on needing to be replaced. I will have to see it in person. If the cranks garbage I don't see anything wrong with using the NA. The block, crank, main bearings, and rods are all the same NA to TT.... Either way the NA motor has to be pulled. What is a few more hours too strip it down to bare block again? I will be doing this over the winter so no big deal on having the car down. Plus i'm only spending $350 for a complete TT motor minus turbos... meaning I'll be able to swap over everything onto the NA block. Hell, I would pay someone $350 for a set of TT heads. The fact i'm getting everything from the oil pan to the exhaust manifolds is a bonus. As an update to all parts I'm getting after multiple phone calls and negotiating: Craigslist guy #1 Complete Twin Turbo motor (no turbos) Nismo 555cc injectors (Expensive $$$) $500Craigslist guy #2 Megan Racing Down pipes Megan Racing Test pipes Intake hard pipes CX racing aluminum intercollers Earls oil cooler and hard lines All intercooler piping 8 pcs Accordian tubes 2 pcs TT EFI harness TT fuel pump and controller Competion stage 2 clutch Fidanza flywheel Ashspec Dual Pass Radiator (Fan and shroud included) Autometer A Pillar 3 Gauge Pod TT rear sway bar All for $1600 I've spent a long time researching this investment and I don't think I would consider using the NA short block (minus pistons) to be "a dime holding up a dollar".... Anything I'm missing here or that I'm just plain stupid please let me know. Once again I'm NO TT EXPERT but I think this is a great starting point. Thanks- Luke
